-   Drivetrain (https://www.s-chassis.com/forums/drivetrain-14/)
-   -   VLSD Swap into 89 240 (https://www.s-chassis.com/forums/drivetrain-14/vlsd-swap-into-89-240-a-21440/)
gst mike Apr 3, 2005 11:01 AM
I think I understand what I need but I wanted to make sure by putting it out there to everyone.
If I pickup a JDM VLSD assembly with the 5 bolt outputs as long as I get the axles with it I will be fine to bolt it up correct?
Also what should the final be on 89 240? 4.08 or 4.40?
Thanks for any help.
4984 5fsdskfvjdsntr4 Apr 10, 2005 04:46 PM
If i remember correctly the stock USDM has the 4.08 final gear.
Depending on which vlsd u get, it could be different.
