-   Drivetrain (https://www.s-chassis.com/forums/drivetrain-14/)
-   -   Who sells SOLID s14 tranny mounts?? (https://www.s-chassis.com/forums/drivetrain-14/who-sells-solid-s14-tranny-mounts-39449/)
bucket240 May 26, 2007 07:36 PM
I need a tranny mount for my s14 but I dont want to settle for the Nismo mount instead I am looking for a solid aluminim or steel mount. WHo knows a web site that sells them??? I need ASAP.:help:
BigVinnie May 27, 2007 01:25 PM
No one does. You have to prefab yourself. Look into cusco's if you want the stiffest tranny mount. From personal experience the NISMO's are stiff enough for track use.........
Just pulling your leg. 240sx motoring sells a whole entire kit, but it's a rough mount to use it could cause a lot of chassis vibration.
http://www.240sxmotoring.com/avracncramom.html
KFL May 27, 2007 06:47 PM
I would just get the peak pro bushing instead its way more solid but gives enough flex so it won't damage the trans. If its a track car only non-street use then those solid trans mount above looks like the way to go. I'm going with the peak street version to replace my nismo just not solid enough to my liking.
bucket240 May 28, 2007 08:24 AM
Thanks for the info, I did some research and found these, they are in australia.
http://racespec.com.au/product_info.php?products_id=117
and here is the one I ordered on ebay: its just the mount.
http://cgi.ebay.com/ebaymotors/Avid-...spagenameZWD1V
BigVinnie May 28, 2007 08:58 AM
As a warning I don't recommend hard tranny mounts. They bend and break bolts. Crack the tranny case, or even break the knuckles to the drive shaft.
