S13 SR20DET Stalling Issues... Help.. Please?
Old 07-28-2008, 07:32 AM
240smoke's Avatar
I recently purchased a 1992 Nissan 240SX SE which was previously an automatic and had a manual SR20 swap done. From what I understand, the SR motor was from an automatic car and has the auto throttle position sensor. The motor harness was hacked up and I had to redo alot of it. I was wondering if anyone might know why the car stalls when I press in the clutch?? It only does this after it is warm. Could this be the TPS? or possibly the Blow-Off Valve? I pressure checked the intake and there are no leaks. The BOV doesnt leak any air either. I am Dumb-founded by this problem. Any advise will be helpful. Thank you.
240smoke is offline
Old 07-28-2008, 12:44 PM
240smoke's Avatar
It prob doesnt help but here is the engine bay.
Attached Thumbnails S13 SR20DET Stalling Issues... Help.. Please?-l_82250319f8590c65327746195e496802.jpg
240smoke is offline
Old 07-28-2008, 12:55 PM
k_wakasugi's Avatar
hmm... what's your idle set at?
k_wakasugi is offline
Old 07-28-2008, 01:07 PM
240smoke's Avatar
I think it idles at 1100 when its cold and around 900 when its warm. The RPMs drop to zero instantly when I push in the clutch. This makes drifting rather challenging. It seems as though it floods out??? I dunno. Im confused at this point.
240smoke is offline
Old 07-30-2008, 04:12 AM
240smoke's Avatar
So I guess noone has experienced this problem then? I did some web surfing and found that the problem may be from my BOV.
240smoke is offline
Lucas7482
01-03-2013 04:06 PM
1991se240sx
02-20-2011 01:09 PM
Jay_240sx
05-30-2009 10:38 PM
DrftDmn
06-25-2003 09:49 PM
EvoMperor
05-27-2003 10:30 PM
Quick Reply: S13 SR20DET Stalling Issues... Help.. Please?
