95-98 Ka24de
Can a 95-98 KA24DE fit into a '93 240 with no problem? does it juss bolt right up? and wheres the cheapest place where i can get one for down in So. Cal?
There are a few differences between the two, but I don't know them all off hand. I think there are a few sensors that you will have to switch to use a later motor with an S13 harness.
I also think you have to retain the S13 distributor. I had all the info somewhere... oh yeah, on my hard drive that crashed... :( -Justin www.saltgod.com |
here's a silly question...why would you want to swap a ka24de for a ka24de?
if u are broke and ur engine just dies..
swapping a de into a de isnt that bad.. it would be a bolt in affair. |
yea i dont know when or if the motor was odb1. But if its a odb2 engine going into a odb1 wirering is a little different which might cause some problems
Yeah the 95 and up were obII i think and they are some differences I think the bolt pattern for the exhaust manifold are different (reason that the Greddy header is only available for 95-98) and so you might want to also look into those factors.
Exhaust bolt pattern is the same - there are other body-related considerations that make the headers different. I think the main consideration for this is the EGR tube.
I know that Don @ pdm racing fit an S14 header into hi S13, so they are probably not TOO far off. -Justin www.saltgod.org |
why not just find a 94+ ka motor..
it would be much simpler.. and i think they should be everywhere.. considering alot of ppl are swapping now adays |
the problem is is dat i dun want a KA24DE engine with alot of miles on it. Cuz i got about 200k miles on mine right now, and im lookin for a motor with around 60k miles on it.
or you could rebuild it and it would have 0K miles on it.
Originally posted by battlestylespl or you could rebuild it and it would have 0K miles on it. |
well he can have my engine while he rebuilds his..
for a small price of course =) |
