-   Engine Swaps (https://www.s-chassis.com/forums/engine-swaps-13/)
-   -   CA18DET good for me? (https://www.s-chassis.com/forums/engine-swaps-13/ca18det-good-me-18244/)
gazelle Dec 13, 2004 09:28 PM
I've been checking out the CA18DET and its looking mighty nice, it weighs less than my ka engine, turboed, cheaper than sr swap and less common, not to mention i can get one for $900 with engine, and tranny. I am not planning on big numbers for horsepower, i just want a little more than the ka. 250 tops. I have read 200 can be achieved with not too much work. Does anyone know the weight of the ca vs sr vs ka?
I've looked around and cannot find engine weight of the ca, i'm assuming its even less than the sr, due to its lower displacement.
Ju excited about some new ideas i have and i have the money to do, wanted to tell someone =D
jonpowell Dec 14, 2004 04:30 AM
CA18 is good for EVERYONE. It has been referred to as the 'mini RB"
jbask Dec 14, 2004 03:27 PM
I also have herd that the ca18det is a killer engine! I had a link some were on my comp, It had results from a dyno day and this guys ca beat most the sr's with very little mods. I will try to find it and post it.
P.S not sayin that sr's suck cuz they don't! they were probly mostly stock;)
jbask Dec 14, 2004 03:31 PM
http://www.n-e-c-c.com/forum/viewtopic.php?t=460
there it is. 244.66whp/225.96trq for the ca
highest Sr there was 240.35whp/260.58trq
SINFUL s13 Dec 16, 2004 12:52 PM
is that stock?
carofchoice Dec 16, 2004 02:39 PM
i had a buddy in japan that had a 300+ hp ca. lots of people see a ca and thing garbage but imo well worth the money.
ArticDragon Dec 16, 2004 04:34 PM
CA is smaller, but is an iron block. So it may be the same weight or just a little less.
rapanett Dec 16, 2004 06:37 PM
My friend just got done building his CA18DET except he had it bored out to a little over 2.0 L with custom pistons. He just got it running today and is still breaking in the motor. He took me for a ride and man does it feel strong. Cant imagine what its like under full boost
4984 5fsdskfvjdsntr4 Dec 17, 2004 01:42 PM
I running my ca and its strong. Now i never drove a sr20 so i wouldn't be able to tell u the difference, but i know once i get it to the dyno in a couple weeks i'll be posting the scores.
If u go to www.norrisdesigns.com they r a tuning company in europe. U can get a basic idea of what u need to reach a certain HP by lookin at their packages. BTW i use one of their chips and its good.
ArticDragon Dec 17, 2004 02:27 PM
Not to mention there are stroker kits for the CA to beefen out the torque.
rkcarguy Dec 19, 2004 11:26 AM
There's a CA here that runs with everyones SR's no problem. Seems you can crank the timing quite a bit before detonation. The iron block is the key, but if you get one pull the pan and locktite/retorque the rod bolts, they aren't torqued tight enough from the factory and we've seen some come loose.
Red240 Dec 21, 2004 09:11 AM
Would you know the torque for the CA18 rod bolts by chance?
Regards,
Catharsis Dec 21, 2004 11:47 PM
download the FSM from here
http://ffdet.com/members/rich/Manuals/s13%20CA18DET.zip
