chevy 350 swap in progress!
just started dropin the motor in, theres suprisingle plenty off room for it, sofar i've only had 2 make motormounts and dent the trans tunnle to get it to set in there right it might take awhile cuz the motor needs rebuild but itll get done.. i'll get some pics up tomorrow cuz its to dark now and im lazy,
4 Attachment(s)
Attachment 5885 finaly got the mounts finished and there it is settin in there
Attachment 5886 Attachment 5887theres the passenger side mount, i know my welds suck but their holdin, i'll eventualy get them rewelded and some more supports made Attachment 5888 had to hammer in some of the trans tunnle to get it to go in |
Nice, i have a fully built Fuel Injected LT1 350 out of a 92 Corvette that i dropped into an S14. The engine and trans is in the car, My brother is a metal fabricator, so he made me motormounts and a crossmember for the tranny and modified the trans tunnel so it looks factory.... I ordered a painless wiring harness from summitt to wire the engine, its awesome, every wire is labeled to tell you where it goes, makes the job 100% easier. Ive built a few S10 trucks with the same setup so as far as cooling im gonna run a fluidine radiator with a flex-a-lite push/pull dual fan setup, The S10's never overheated with that, so hopefuly ill have the same luck with the S14. By the way, sorry to threadjack you
nice, any pics?
cool cool whats the status of completion
its gonna be awhile as of now its just a bare shell with the motor in and wheels, and im still tryin to decide if i should go with a high compression setup or turbo it, all ive decided sofar is its gonna b stroked to a 383
torque city!
What tranny is that? turbo 350? I say a 10:1 383, World Or Dart Heads in the 195 range, A 234/234 cam in the low .500's lift, edle single plane, 750 carb of your choice. That would be right at 420 crank horsepower. I have a virgin 400 crank sitting in my garage. Came out of a solid running 2 bolt main motor. |
yeah its a turbo350. that sounds like a good setup, mby i'll go with that but with like a 11-1 instead of 10-1
do you have a crank to make a stroker motor? I've had this crank forever and ill let it go cheap.
im probaly just gonna go with a eagle stroker kit. but how much do you want for it and whats it out of?
Sorry for the long reply. If you pay shipping plus 40 bucks, you can have it. It's out of a 73' chevelle.
Not good. Thos frame rails are not that strong, you want to brace it to the stock crossmember. I used a TH350 in my S13, it was a ***** making it work with a LSX motor. I have a 460 horse 11.5:1 small block 400 I was going to use, but I decided to go with a new gen swap.
Beast Mode!!!!
