drive shafts
Old May 4, 2005 | 09:50 AM
'89'notchback's Avatar
drive shafts
I got a rb20 im puting into a '89' 240sx dose anyone know the legnth of the new driveshaft I will need Im using mckinny motor sports mounts
Old May 4, 2005 | 02:46 PM
jonpowell's Avatar
RB20 uses stock 240SX driveshaft.
Old May 4, 2005 | 04:16 PM
iroc07's Avatar
as long as the car was a manual tranny to begin with. if you are converting while doing the swap you need to pick up a manual driveshaft somewhere.
Old May 4, 2005 | 06:39 PM
Thanks I knew you could with the skyline crossmember but I didnt know with the mounts
Old May 5, 2005 | 12:42 AM
iroc07's Avatar
the mounts shove the motor back a little tiny bit so it takes up some of the slack you would have if you used the skyline X-member. I make my mounts a little different than tophat or McKinney so you have about half the amount of play, but if you stick an LSD in you arent smashing everything together. My mounts are right in between where the R32 xmember and tophat mounts put the motor, about 3/8" instead of 3/4 .
good luck on your swap, hope you have fun doing it.
Old May 5, 2005 | 04:01 PM
Alright well thanks for the info
s14Drifter
Sep 28, 2008 11:17 AM
Carparthookup
Sep 14, 2005 11:38 PM
nissandrift
Oct 6, 2004 08:09 PM
yiaracer
Mar 9, 2004 11:10 AM
JeromeS13
Mar 7, 2004 11:58 AM
