-   Engine Swaps (https://www.s-chassis.com/forums/engine-swaps-13/)
-   -   drop in? or drop onto? (https://www.s-chassis.com/forums/engine-swaps-13/drop-drop-onto-7096/)
s13_bb2. Oct 28, 2003 09:05 PM
Do most of you that have done swaps put the motor into the car through the hood? or lower the car onto the motor?
-HyJynX- Oct 28, 2003 10:20 PM
Im trying to do mine by droppin the engine in the car..but its kinda hard when the engine is so god damn long.
<<RB20 swap
Doba's240 Oct 29, 2003 04:15 AM
yeah i put my sr20 into the chassis with transmition and downpipe
little problems
jonpowell Oct 29, 2003 04:45 AM
I dropped the RB25DET in through the top, if I did it again, I would go from the bottom with the trans already bolted up. Much easier. RB is a ***** from the top.
-HyJynX- Oct 29, 2003 08:45 AM
:werd: did u use the tilt on ur engine lift or just dropped it?
jonpowell Oct 29, 2003 09:23 AM
I actually hung a chain from s roof beam, no engine hoist here....
-HyJynX- Oct 29, 2003 09:26 AM
god damn haha, hardcore lol. Im havin trouble fittin my RB in:confused:
Nismo241 Oct 30, 2003 12:03 AM
Tilt the back down and the front up. Rock it a little so the clutch gets past the lip on the firewall, and let that part get down past it. Then push it back as far as you can to clear the crank pulley from the core support. Thats how I did mine both times and thats how I did the other swap I did.
jonpowell Oct 30, 2003 04:21 AM
Hyjynx, you and I talked about this before and I told you it would be easier to assemble the trans & motor and THEN install it into the car from the bottom. I have another swap coming up, RB25DET into an S14 and I will try it that way and tell you how it goes.
I didn't really have any trouble lowering it into the car, just gotta make sure you are as close to the firewall as possible.
-HyJynX- Oct 30, 2003 09:47 AM
ok guys, ima try to do it again tomorrow and hopefully be succesful. Ganna be another fun day:D
Sil40_Mayhem Oct 30, 2003 10:13 AM
best of luck w/that!:thumb: let us know how it went down...
-HyJynX- Oct 30, 2003 10:25 AM
Thanks bud:thumb: Hopefully it will be all go0d
Spec_v5150 Oct 30, 2003 08:47 PM
We dropped mine in tranny and all. Slid right in. No problems whatsoever......
-HyJynX- Oct 30, 2003 08:56 PM
well ill get back to u guys tomorrow bout how it goes. me and my friend did a lil test fit and it didnt fit right, but then again the chain was in the way and we couldnt fit it in properly at all.
