feelin kinda shaky, need oppinions
Ok i'm thinkin about buying this 240 i found with a sr20det swap already done. In the description it says its intercolled by a 15"X20" Volvo 9000 intercooler thats sandwiched between the radiator and condenser. Has anyone heard of anyone doin this. Is this safe. Ill probobly get a blitz intercooler kit immediately after purchase, but just wanted to see what you guys thought. The person also said they have a Bosch BOV which vents back into the system so it does not screw up the fuel injection. I was planning to get a Blitz BOV that doesnt vent back into the system. Will the blitz mess up the fuel injection that much, or should i just stick with the bosch? Thanks
Just buy the car and get a blitz intercooler and bov. Never heard of that svrewing up fuel injection:thumb:
I've heard of peoples car's stalling but they's a lot of ways around it.
the BOV is a mass air flow issue.
if you vent to the atmosphere, the air you let out has already been registered by the MAF sensor...which means the A/F ratio is already set to pump out that amount of fuel. if you vent out that air then the car will bog out because of too much fuel. :thumb: that volvo intercooler was a cheap effort to intercool the air. he probaly didnt have enough money for a real intercooler. if it works it works but probaly not too efficiently. a larger front mount will do the trick just fine bosch BOV's are just fine...they all do the same job. release air preasure....if i were you i would save that money for a new fuel pump and boost controller just my 2 cent |
