Fuel Pump
You can run it, but the pump wont last very long at all. Especially if you crank up the boost at all, it will lean out and cause tons of probs. If you havent already, upgrade to a walboro or a 300zx TT fuel pump
I went with a Denso fuel pump, a lot better than el cheapo Walbro IMO!
http://www.store.yahoo.com/phase2mot...sr20detfu.html MAX boost I ever ran was 15psi,stock T25
Originally posted by ridesnowx4
my advice is to get a TOMEI fuel pump... its adirect drop in, the 300zx fuel pump doesnt fit right in.... you have to make it work.
http://www.store.yahoo.com/phase2mot...s1nis24fu.html
I ran a RB25DET on stock 240SX fuel pump with 10 psi and had ZERO problems and was still running rich. The stock fuel pumps aren't all that bad....just don't test your engine at 15-20psi or you could go lean.
nsn240
Oct 20, 2006 09:50 AM
