-   Engine Swaps (https://www.s-chassis.com/forums/engine-swaps-13/)
-   -   Guide for ka24e to ka24de (https://www.s-chassis.com/forums/engine-swaps-13/guide-ka24e-ka24de-17530/)
lrb_2000 Nov 18, 2004 12:40 AM
Does anyone have a guide or something on how to remove a ka24e from an 89 240sx? or should I jsut go buy a book?
jonpowell Nov 18, 2004 04:46 AM
no guide that I know of, but removing ANY engine is the same procedure...
Remove battery
drain coolant
disconnect electrical, powersteering lines, heater lines, AC lines, & all vacuum lines, remove radiator
remove driveshaft
remove shifter
loosen all trans & motor mounts
attach engine hoist to engine
remove mounts & yank
install is reverse of this.
srslider Nov 18, 2004 06:27 AM
oh, yeah don't forget fuel lines, and the clutchfan!! Gravy job dude it should take you 2-3 hours depending on how much you work on cars.
