I need install instructions for s14 walbro fuel pump
I just bought a walbro fuel pump to put on my r33 rb25 powered s14. I was wondering if anyone knew how to install a fuel pump and if you did could you please post how.. thanks
unscrew the bolts covering the fule pump in the trunk floor
unscrew the plate on top of the tank remove the lines & unplug follow wiring directions that came with pump reverse process |
The pump I received did not come with the wiring instructions. Does anyone have a copy?
the pump cover is plastic and is one of the ones you have to bang it in a circle untill its loose enough. other than that it is take the pump out and do everything in reverse to put the new one in.
http://www.paulboz.com/fuelpump.html
If you get to the area where all the hoses and plugs for the fuel pump is at, then you can see the round locking thingy. I had to use my rubber mallet and spike to help turn the lock. The rest is as above describes. I did it on my s14 today. |
