Little stumped
Hey guys. I'm swapping an SR into an Altima and I'm kinda stumped as to the wiring. Anyone have any links or books I could pick up to help out? How did you guys wire up your Sr's? Thanks in advance for all the help guys!
Josh |
So nobody here actually does the work themselves?
Have you checked out srswap.com
A friend of mine did this swap and actually used the existing wiring harness and then had JWT retune the ECU. Nissan's are fairly simple most of the time you swap out the entire harness from engine to computer and then hook up the dash wires to the JDM harness. Not experienced with your particular application personally tho.
