-   Engine Swaps (https://www.s-chassis.com/forums/engine-swaps-13/)
-   -   my sr20 sit uneven, why??? (https://www.s-chassis.com/forums/engine-swaps-13/my-sr20-sit-uneven-why-21865/)
advanced240 Apr 17, 2005 02:41 PM
ive got the motor in and the mounts back on and i cant seem to get it to level out. the left side of the motor is lower that the right have any of you ever encountered this problem??? is their a spacer that i could use to level it....
TWAN Apr 22, 2005 06:07 AM
Double check your motor mounts. They can only go on one way. Also make sure you removed the AIV from the down pipe from the turbo. If you didnt more than likely it is sitting on your steering assembly. If either of these arent the case you might have the wrong mount on one side or a busted mount. Hope this helps. :thumb:
Bryan Apr 22, 2005 12:43 PM
whats your poll have to do with this question...
98cwitr Apr 23, 2005 01:44 PM
^he might be killing two birds with one stone, hehe
rkcarguy Apr 23, 2005 07:08 PM
The motors sit uneven like this from the factory. I have 3 SR clips in the shop right now they all sit uneven, lower on the turbo side of the engine.
Slidin240 Apr 24, 2005 10:11 AM
Ive noticed that too with the SR/RB motors. Everytime i see one its on a slant (on the turbo side)
advanced240 Apr 25, 2005 08:20 PM
thanks a bunch, now i have a new problem "too long of a drive shaft non-abs". thanks a bunch guys...
