my sr20det wouldn't start
i have a 92 240sx with a sr20det blacktop. it was running fine and one night it just wont start. starter and battery was tested and it was good. car turns on and when i turn the key i get 1 click and nothing else. i need help!!!!!!!!!!!
Wiring problem?
Originally posted by -HyJynX- Wiring problem? |
does the click sound like the starter or is it like a wire is grounding get a friend to help with that
One of the wires isn't connected properly or you've got a short somewhere along it's path. I had a bad terminal and it did the same thing. Try getting someone to play with the wires while you crank it.
thanks i found the problem. it was an open connection with the wires.
