-   Engine Swaps (https://www.s-chassis.com/forums/engine-swaps-13/)
-   -   need help fast ka24de/rb help (https://www.s-chassis.com/forums/engine-swaps-13/need-help-fast-ka24de-rb-help-6800/)
cheap240 Oct 15, 2003 06:45 PM
i wanna buy a ka24de from a 95 se it comes w/the engine and ecu but the guy tells me he need the harness for his rb20 i think swap. i have a 90 w/ka24e. can this be done w/o his harness or does he need it, i need help tonight asap thanks
Nismo241 Oct 15, 2003 09:51 PM
Re: need help fast ka24de/rb help
His motor harness is useless for an RB. There is no way it can be used. The sensors are different and there are 2 more injectors than the KA so the injector harness won't work. It's distributerless so the KA dist harness wont work. There is a CAS on the RB that the KA doesn't have and all sensors are different. All thats so if he argues about it you have stuff to back it. Good luck. Also you need to have the KA24DE harness
