Power Steering--> Manual Steering
Old Jan 13, 2005 | 09:54 PM
JDMxDrift's Avatar
I currently have power steering on my S13, when i get my swap done, is it difficult to switch to manual steering? Can i just take off the PS pump? Do i have to get a new steering rack?
Old Jan 14, 2005 | 09:33 AM
Skiboard06's Avatar
no it is not difficult to switch over to manual steering. remove the pump and attached belt. then remove your power steering fluid resovoir. Follow the steel lines from the pump back to your steering rack. unbolt the lines here. turn ur wheel back and forth a few times to get out excess fluid and then cap off the holes where the lines were with some large bolts. This will provide you with an adaquete manual steering setup
Old Jan 14, 2005 | 09:59 AM
twofotisx's Avatar
why do you want to kill the power steering? in order to be in a certain race class?
Old Jan 14, 2005 | 10:25 AM
JDMxDrift's Avatar
one less thing that can break on my car. and it gives a floaty feel while i'm driving. And +17 rwhp
Old Jan 14, 2005 | 07:09 PM
sup man im buying a ca motor can i do the same for that
thanks
Old Jan 14, 2005 | 08:23 PM
Catharsis's Avatar
you dont want an s13 witout power steering. ther eis no manual steering rack for the 240sx silvia or any other nissan that is close to it.
its a bad idea
Old Jan 15, 2005 | 02:16 AM
iroc07's Avatar
its not much work to keep it. if youare doing RB swaps I can convert everything you need for $40, and it only takes me a few hours to do it all. SRs I thought were just a matter of wrapping the lines to the other side for the rack. for those, just get a tube bender, and flare tool and start makin some lines.
Old Jan 16, 2005 | 01:46 PM
Skiboard06's Avatar
im not sure if u can do that for a ca sorry i just dont know if the lines from a doch ka will bolt up no experience there
Old Jan 16, 2005 | 08:02 PM
Catharsis's Avatar
yes you can
the CA swap is jsut like a sr swap only with a different motor and a few different wires
Old Jan 21, 2005 | 07:56 PM
stannyboy's Avatar
hmm removing power steering.. makes no sense.. you can't handle a car w/it feels too sloppy.. change out the steering rack bushings.. when the motors out.. still not enough feel for you change out all the front arms.. But its your choice I will laugh when you take it out drift.. drift.. drift.. then your rack goes bad cause it dries out.. then your stuck on trying to get to car to turn while you should be focusing on your line.. Then you want Power steering again.. how do I know.. Same happened to my friend.. good thing I had and extra rack for him... so I would think about it long and hard before you decided to not use it.
Old Jan 21, 2005 | 09:51 PM
Originally posted by Catharsis
yes you can
hey sup man do u know the exact wires that i have to modify
Old Jan 22, 2005 | 03:49 AM
Catharsis's Avatar
yes i just wired mine today i will take some pics for y tomorrow to help ya along
Old Jan 30, 2005 | 07:25 AM
DTS's Avatar
DTS
my car was hardly faster with or witout powersteering
and i drove with no powersteering for 1.5 months, and anyone who says you cant control it and cant drift has not driven a non powersteering car.
yes that statement is true if your a weak person, when i first drove with no ps i found it hard to drive quickly into corners because there was so much force on the steering, but after 2 weeks i was noticably stronger and had no problem drifting or ripping threw on and off ramps.
however the reason i had no ps was because my hicas distrubution block blew at 200kph sending atf all over my nur spec and made a huge cloud of smoke.
but to sum it up, i bought a new hicas block and im fixing it over winter. powersteering is much nicer!
Old Jan 30, 2005 | 08:39 PM
Catharsis's Avatar
its still pointless the s13 was designed for powersteering period
ther eis no reason to not have PS
Old Mar 4, 2005 | 11:39 PM
Sil80 type X's Avatar
well if you think about it, and decide to get rid of your power steering, sell the lines and resovior to me, because im swaping a sr20 into my 89 240, and i need the power steering parts for the swap.
