rb25 greddy intake mani help
Old Mar 6, 2005 | 02:06 PM
Jewellz's Avatar
well im finally installing my greddy intake manifold well i have a question for anybody thats ever done this..
i blocked off the hoses the instructions told me to but theres still a coolent line that runs from the turbo around the back of the block to the passenger side of the car, and i cant find where to put it or hook it too. hopefully youll understand what im talking about..
-Ry
Old Mar 7, 2005 | 11:26 AM
iroc07's Avatar
I think you should still be able to match up where that was on motor, and reattatch it without to much problems. I think that Ts into another coolant line, but I cant remember. I would have to look. I can check it out later today if you still cant get it.
Old Mar 7, 2005 | 11:34 PM
Catharsis's Avatar
block off the coolant lines
Old Mar 8, 2005 | 01:19 PM
iroc07's Avatar
block off the coolant line to the turbo????????? You might wanna do that on your car, but I wouldnt give that advise to someone else. That thing is on there for a very good reason.
Old Mar 8, 2005 | 02:31 PM
Jewellz's Avatar
well, i still dont know, i shows to block off two of the lines, which i did, but the third i have know clue as to where it goes or where to t it into, i cant read the instructions cause there all in japanese im just about to guess where it goes, cause there is no spot on the manifold for it..
thanx
-Ry
Old Mar 8, 2005 | 08:49 PM
Catharsis's Avatar
no they are mostly worthless oil does far moor cooiling than the coolant can
Old Mar 9, 2005 | 02:34 PM
Jewellz's Avatar
well if anything ill just t it into any random line, but im gonna take a good hard look at it first before i blow somethin up..
-Ry
Old Mar 13, 2005 | 03:40 PM
Jewellz's Avatar
anybody with ideas, huh??
-Ry
Old Mar 13, 2005 | 03:47 PM
iroc07's Avatar
figure out if its a send or return line, and then hook it to the closest thing that works.
Old Mar 14, 2005 | 08:28 PM
rkcarguy's Avatar
It goes to one of the heater hoses, I have a RB on the shelf here and the turbo coolant line goes into this small assembly of fittings on the underside of the intake in the back. That's probably not there on the Greddy intake so T it in to either heater hose.
Old Mar 15, 2005 | 01:54 PM
Jewellz's Avatar
ok thats what i was thinking of doing, sounds good, thanx
-Ry
BlackZenki82
Jun 17, 2009 01:09 PM
jwmaxse
Apr 10, 2006 09:49 PM
RandyJordan
Apr 2, 2006 06:32 PM
Heely
Mar 13, 2006 07:23 PM
240sxsilvia
Jan 21, 2006 11:50 AM
