-   Engine Swaps (https://www.s-chassis.com/forums/engine-swaps-13/)
-   -   rb25 greddy intake mani help (https://www.s-chassis.com/forums/engine-swaps-13/rb25-greddy-intake-mani-help-20640/)
Jewellz Mar 6, 2005 02:06 PM
well im finally installing my greddy intake manifold well i have a question for anybody thats ever done this..
i blocked off the hoses the instructions told me to but theres still a coolent line that runs from the turbo around the back of the block to the passenger side of the car, and i cant find where to put it or hook it too. hopefully youll understand what im talking about..
-Ry
iroc07 Mar 7, 2005 11:26 AM
I think you should still be able to match up where that was on motor, and reattatch it without to much problems. I think that Ts into another coolant line, but I cant remember. I would have to look. I can check it out later today if you still cant get it.
Catharsis Mar 7, 2005 11:34 PM
block off the coolant lines
iroc07 Mar 8, 2005 01:19 PM
block off the coolant line to the turbo????????? You might wanna do that on your car, but I wouldnt give that advise to someone else. That thing is on there for a very good reason.
Jewellz Mar 8, 2005 02:31 PM
well, i still dont know, i shows to block off two of the lines, which i did, but the third i have know clue as to where it goes or where to t it into, i cant read the instructions cause there all in japanese im just about to guess where it goes, cause there is no spot on the manifold for it..
thanx
-Ry
Catharsis Mar 8, 2005 08:49 PM
no they are mostly worthless oil does far moor cooiling than the coolant can
Jewellz Mar 9, 2005 02:34 PM
well if anything ill just t it into any random line, but im gonna take a good hard look at it first before i blow somethin up..
-Ry
Jewellz Mar 13, 2005 03:40 PM
anybody with ideas, huh??
-Ry
iroc07 Mar 13, 2005 03:47 PM
figure out if its a send or return line, and then hook it to the closest thing that works.
rkcarguy Mar 14, 2005 08:28 PM
It goes to one of the heater hoses, I have a RB on the shelf here and the turbo coolant line goes into this small assembly of fittings on the underside of the intake in the back. That's probably not there on the Greddy intake so T it in to either heater hose.
Jewellz Mar 15, 2005 01:54 PM
ok thats what i was thinking of doing, sounds good, thanx
-Ry
