s13 red top, no crank
sup guys..
just just dropped a sr in pluged everything up, and this is what happened
-fuel pump not coming on when key is turned
-starter not clicking, which means no crank
however i am hearing clicks from the relays...
what can be the possible problem here?
my guess was something with the ignition signal.
please help!!!
please help!!!
tried to solve things today...
found out that the starter is bad.
and figured out that the check engine light doesnt come on when the key is turned...
and also when i turned the key off all the dash light stays on.. 0_o?
If I were you, Id recheck your harness, sounds like someone didnt do such a great job on the harness. I did my harness myself on my first swap, it was surprisingly easy. hour or two of wiring and done! Look up the wiring specs and check it over is what I would do, there is definatly something weird going on with it. Did the car run fine prior?
yea the car ran fine before..
yea im going to go over my harness again...
im getting crank but no spark but ill only get crank if i wire up the starter straight to the battery...still have a problem with the key do yu think its the key it self?
