s13 or s14?
i have a decent question. i have a 95 240sx and am looking to do an engine swap for a turbo sr20det. my question is, i have a s14 but would i be able to put in a s13 sr20det or do i have to have the s14 engine. i am curious because the price difference in these engines is a little over a thousand dollars. thanks.
Any motor will fit. S14 will be newer than all red top S13 SR20DET's, but there were some blacktop S13 SR20DETs produced at the same time S14's were being produced. These black top S13 SR's will be a little more expensive than red tops - they came in 180SX's and do not have variable valve timing.
If you're planning on upgrading anyway, the red top is probably your best choice. I believe the S14 has a slightly better turbo, but its head design is considered to be less ideal. The S13 red top uses the low-port design. I haven't thrown either of these heads on a flow bench so you may want to seek a second opinion.
-Justin
-Justin
Is it just the intake manifolds, or the position of the intake ports on the head? I was a casual observer on the SER lists for a while, and it seemed that there was a distinction between the two and they always referred to it as a high or low port head.
-Justin
-Justin
I'd say S13 redtop.
If you plan on keeping it completely stock then you may be better off with an S14 or S15 motor. But the price difference for those motors will give you more power if you spend it on upgrades for the S13 motor.
-Justin
-Justin
vtrdcamry2000ce
Mar 24, 2008 07:34 PM
Evo3
Dec 31, 2006 11:08 AM
nebrs13
Sep 28, 2004 12:03 AM
240mph
Jul 7, 2004 07:23 PM
iceperformance
Oct 8, 2002 07:23 AM
