-   Engine Swaps (https://www.s-chassis.com/forums/engine-swaps-13/)
-   -   s14 sr into 97 240 need help with wiring issues (https://www.s-chassis.com/forums/engine-swaps-13/s14-sr-into-97-240-need-help-wiring-issues-21349/)
GREENs14 Mar 30, 2005 06:09 PM
i have the engine harness out of both my 240 and clip, but i noticed that the boost pressure sensor wirirng drops through the junction block and into the loom in the fender well. do I cut the wires, pull them through, and trace where they go to rewire? do I eliminate the sensor somehow? or do i need to cross over all that extra wiring and that junction block?
also there is an 8 wire connector in cabin on the 240 harness i think it heads back to the evap system but cant find it in the fsm anyone familiar with this its a 97 240 by the way
appreciate any help thanks
