S14 SR20DET JDM Kouki ECU Pinout??
Does anyone have the pinout for the the JDM Kouki ECU S14 SR20DET? I'm trying to finish up my swap into my my S14 Kouki and could really use this.
try this link, it may have what you need.
http://www.midweststreets.com/240SX/ecupin.html |
thanks for the link but they only have the zenki pinout which is different from the kouki. I can't seem to figure out the A/C wiring for the Kouki ECU.
na kouki s14 ecu
Hey guys just wondering if anyone has found the na ecu sr20det kouki pinout or f4 interior plug pin out i have been looking for it the last few days and have found nothing but dead ends? i am swaping a s14 kouki sr into a 180sx but cant seem to get it to fire up, it turns over but doesnt start. everywhere i look its either a different ecu pin out for s14 or a zenki pinout. help would be appreciated.
hey man, we have the pinouts for the s-chassis. If the a/c is all you are having an issue with it is pin 41(a/c request) and pin 11(A/C) relay
Derkish, to start out did you check the voltage on the on the injectors, coils, and cam angle sensor?
