-   Engine Swaps (https://www.s-chassis.com/forums/engine-swaps-13/)
-   -   single cam to twin cam (https://www.s-chassis.com/forums/engine-swaps-13/single-cam-twin-cam-31642/)
gizmo Apr 1, 2006 08:07 PM
i have a single cam and i need to swap it to a twin cam ka wha would i need to do the swap besides the motor, tranny, ecu, wiring harness?
soldierdude262 Apr 1, 2006 11:26 PM
ummm I'm not sure you need to swap the tranny, unless you're goin from auto to manual. If I'm wrong someone kindly correct me.
gizmo Apr 1, 2006 11:28 PM
what about the motor mounts? would i need to buy diff ones or will the ka fit the single cam motor mounts?
gizmo Apr 21, 2006 07:54 PM
anyone?
indyvang Apr 21, 2006 07:56 PM
i'm doing the same project...need help swap single cam to dual cam...motor mount is the same cause SR20 used the same mount as the KA..other than that i don't no..
gizmo Apr 21, 2006 07:59 PM
ic well i have the ecu, wiring harness, tranny, my friend did a sr20swap on his car so he has all his old parts all i was waiting for was to know if i needed diff motormounts. if i dont that means its a straight swap
indyvang Apr 21, 2006 08:05 PM
yeah...is better if u change all the old parts out and puts new parts in..since the motor is still out and easier to fix..pully, water pump, n ect...
