SOHC into S14
hey whats up guys im swapping th8e sohc motor into my 95 and was wondering do i0 need to use the s13 wire harness or will mine be the same? i need info asap so any help is good thank you
however if that is not the case then i'd have to agree that it is not a worth doing.
You will have to modify you s14 harness with the s13 harness. I know you will have to change the maf plug, distributor plug, injector plugs. Also since the S14 uses an internal coil you will have to modify it to use external one for the s13 distributor. Now for the ecu you might be able to use your S14 ecu with the ka24e motor.
well i got a s14 n only had a torn up blocl that came with it i have a sohc laying around with less than 70 thousand miles n tranny and all the good stuff and why not be different? why shud i get the dohc cause its the poular way i want a challenge im not looking to make over 300hp thats nonsense for street and for it to be reliable im just looking for awnsers not down talk if u dont like it dont post ur negitives any help i would like tho thank you
