SR wont turn over????
Well I just recently installed an SR into my 91' 240 and when i turn the key to "accessories" you can hear the fuel pump come on (walbro 255lph), but when you turn the key to start the car the fuse almost always blows and it wont start. Anyone have any Ideas on what th problem might be?
And people get mad when I suggest searching?!?!?!
i dont know if it is the same problem as the other guy. he is blowing fuses. you might want to check your wiring to make shure everything is right. something has to almost be grounding out or over amping that fuse to make it blow. just double check your wiring if its not your trigger wire on the starter. doesnt it suck so bad when your finally ready to start it and.................................... click. nothing. i hate that feeling. good luck though man. youll find it. :thumb:
