SR20 Swap Questions
This post is for a friend, I am trying to help him out. I've been a member here awhile as I have always been interested but never had the cash, anyways on to the question.
He did a swap and is certain everything works as his cousin and him did none before but this time the car has NO power, no headlights, inside lights, dome lights.. NOTHING. Although the battery has power to the fuse box and from what he said he has replaced each fuse. Anyone can give him/me any ideas on what it might be? He had a 92 and is swapping a red top, if I remember correctly. Thanks for the help --Z |
id say check your grounds its supprising how often a loose ground is the problem.theres got to b a short somewhere after that fuse box. this may b a stupid question but did they swap the ecu as well?
We check all of the grounds, and yes the ECU was swapped as well.
did u guys do all the wirings rite??
Thats stuff in your body harness, and should have nothing to do with the swap wiring. My guess would be that you main fuse block or the interior fuse block is not getting power. Use a test light to see where there is power and where there is not. If all the fuses have power, then something big in you body harness is not hooked up.
Test light is the way to find it |
will the wire harness from the sr hook um to a 1990 240?
| All times are GMT -7. The time now is 04:34 AM. |
