sr20 w/ ka tranny
will an sr engine work with a ka tranny? if so how reliable is it and is it worth it?
or should i just do the sr swap, tranny and all? |
the ka tranny will not work with the sr engine the sr has a clutch and flywheel from a maxima you will need to buy the sr tranny if you want to do the swap
u can actually use the ka tranny but just change the bellhousing.
| All times are GMT -7. The time now is 02:11 AM. |
