-   Engine Swaps (https://www.s-chassis.com/forums/engine-swaps-13/)
-   -   Sr20det BOOST (https://www.s-chassis.com/forums/engine-swaps-13/sr20det-boost-12567/)
doua May 17, 2004 06:49 PM
Sr20det BOOST
I was wondering how much can you Boost the Storck Sr to. I have a boost controll and need to know what is the safe point. Help if any one,
Yellowcell May 17, 2004 06:54 PM
which one? redtop black usually 13-15psi for safe.. it comes with 7psi stock. go here *****! http://srswap.com/ and go to motor faqs!
doua May 17, 2004 07:07 PM
Thank man< It is nice to know that.
-HyJynX- May 17, 2004 08:23 PM
You can only boost about 9-10 if you have the stock SMIC.
rudee023 May 18, 2004 08:32 AM
To be safe I would upgrade your fuel pump before I started upping the boost. A $100 Walbro is alot cheaper than a new motor. After that 10psi on a stock sidemount and 14-15psi on stock turbo/injectors.
Yellowcell May 18, 2004 09:32 AM
well so u guys are saying i need to upgrade the fuel pump and rail injectors?..... to how many cc's?
gerbort May 18, 2004 10:48 AM
no...he's saying up to 10 psi is safe w/ stock SMIC and a upgraded fuel pump...want to go higher...get a better intercooler...then you can go ~14 psi.....after that you're beyond the efficiency of the turbo...if you want to go higher than that get a better turbo and upgrade your injectors...wouldn't hurt to upgrade injectors...then you need to get an SAFC to control
-HyJynX- May 18, 2004 11:04 AM
gerbot got it right, but I would only boost to 13. Most people go 550CC's.
