-   Engine Swaps (https://www.s-chassis.com/forums/engine-swaps-13/)
-   -   sr20det + dofferential (https://www.s-chassis.com/forums/engine-swaps-13/sr20det-dofferential-35278/)
aurora61 Oct 5, 2006 11:00 AM
i recently bought a tomei 2way lsd for my open differential pumpkin. With that said, if i want to swap in a sr20det with the tranny in the future, will i be able to use the stock ka24e differential?
If not, is there something i could do....like buy a new driveshaft or something?...cause i want to keep the 2 way differential.
Bryan Oct 5, 2006 11:14 AM
The rear differential has nothing to do with the engine that is in the car. Everything will still be there once you swap.
aurora61 Oct 5, 2006 12:04 PM
Even with the new/different sr20det transmission? Im asking this cause im thinking that maybe the driveshaft bolt pattern and driveshaft length will be different after the swap
MS!3 Oct 5, 2006 12:50 PM
its the same, you even use the same driveshaft when you swap.
zenkislider Oct 5, 2006 01:08 PM
yep it will all work...the sr and ka tranny are pretty much exactly the same.
aurora61 Oct 5, 2006 01:35 PM
thanks alot guys
