sr20det heater hoses
Old Nov 20, 2003 | 11:17 PM
s13_bb2.'s Avatar
im currently doing my swap into an s13 and was wondering what you guys have used to connect the heater hoses together. I read an article that suggested 5/8 to 3/4 in hose adapters, but i havent been able to find these.. anyone have any suggestions?
Old Nov 21, 2003 | 12:36 PM
Jonas's Avatar
i forgot what i used, but it was some little metal pipe i got from the ka... basicalyl anything that will fit inside the 2 lines..and be sure to tighten these... heater hose leaks are ghey when your motor is all in and situated...
Old Nov 21, 2003 | 11:12 PM
s13_bb2.'s Avatar
are the two hoses the same diameter? or is one bigger than the other?
Old Nov 22, 2003 | 05:18 PM
Judge's Avatar
look at them and you tell us.
Old Nov 22, 2003 | 07:37 PM
Jonas's Avatar
lol, dood just get a freaking piece of little pipe from the homedepot plumbing section that will fit inside the heat hose... buy some hose clamps and insert them and tighten down?? what is so complicated about that?? all that matter is that coolant gets where it needs to be and it doesnt leak... simple as that
and yes they are the same diamter
Old Nov 23, 2003 | 07:54 AM
Judge's Avatar
I'll tell ya what...where are you located? If you are close enough I will make you one out of stainless steel for lets say/........ $200...sound good to you ?
bestint
SR
Oct 8, 2010 03:30 PM
Treyz
Feb 21, 2007 02:54 PM
nvrstock
Oct 25, 2005 03:59 AM
tegg_gsr
Feb 20, 2004 03:15 PM
240GyRl*
Nov 15, 2002 10:28 PM
