Twin Cam Head on Single Cam Block??
Hey, i was just wondering if it was possible to put the twin cam Head on a single Cam Block?
IIRC, not possible. Or there is a lot of customization to do.
it is posible but you will need the twin cam ecu, all the manifolds and sensors. it also boosts your compresion ratio to somtthing like 11:1 and that on the stock sohc pistons probibly wouldnt work very well:tear:
Originally posted by franman s13 it is posible but you will need the twin cam ecu, all the manifolds and sensors. it also boosts your compresion ratio to somtthing like 11:1 and that on the stock sohc pistons probibly wouldnt work very well:tear: |
