wiring harness advice needed - 89-90 car harness's
Ok, so here's the deal...
I'm working on a certain car that has a certain motor, that I'm using a 89-90 wiring harness (engine bay AND Interior harness's), Sorry I can NOT give details out, the owner has me under strict orders not to talk about the car or the motor. so please bear with lack of many many details about the project. YES, I do have the FSM for the wiring, but I'm not fully sure about some stuff. What I have is a 1989 240sx wiring harness both interior and engine bay harness. I have removed many many wires and relays from both harness's such as... A/C Relay ABS Actuator ABS Control Unit Auto Antenna Timer Automatic Seat Belt Control Unit Automatic Trans Ctrl Unit (A/T Ctrl unit) Blower Motor Blower Relay Brake Fluid Level Switch Cruise Ctrl hold relay Cruise Ctrl steering switch Cruise Ctrl switch Cruise Ctrl unit Door Lock Timer Door Switches fan switch fog light relay fog light switch glove box light switch headlight wiring (by accident, need to rewire into harness) left retract motor overdrive indicator overdrive switch power mirror switch power window main switch rear window defogger relay rear window defogger switch rear wiper/washer system retract switch right retract motor sunroof system washer fluid level switch washer motor wiper/washer amp *I need to know if that I can use just engine bay harness that has the relay/fusible link box, without the interior/dash harness, and the motor still be able to start and run? (more below the pictures) This Relay Box: http://img218.imageshack.us/img218/4462/relaybox2.jpg and this big white plug: http://img218.imageshack.us/img218/8...essbigwhit.jpg The full engine bay harness: http://img218.imageshack.us/img218/6...arnessfull.jpg as you can see I have removed many many wires... http://img231.imageshack.us/img231/2...esjune0609.jpg Interior Harness (In progress of removing wires and accessories): http://img218.imageshack.us/img218/6...sscomplete.jpg Interior Harness Fuse Panel and Big White Plug: http://img218.imageshack.us/img218/2...ssbigwhite.jpg *Does the white plug make a loop circuit, where as that it has to be plugged in to make the engine start and run, or not? *If I can not use just the engine bay harness alone, what do I need from the interior harness to get the motor to run? |
Do these two plugs have to be plugged in, for the motor to be able to start and run?
Do they make a loop for some accessories that are needed? (Just a easier way of saying what I said above!!!) This big white plug: http://img218.imageshack.us/img218/8...essbigwhit.jpg And this big white plug: http://img218.imageshack.us/img218/2...ssbigwhite.jpg |
| All times are GMT -7. The time now is 07:01 AM. |
