won't turn off
my engine won't turn off. when i turn the key too off. what is wrong??
the oil light and the other dash lights stay even when i take my key out the ignition. what is wrong?????????????????????? |
messed up ignition cylinder by the sound of it. they are a pain in the A$$ to change too. you need to drill out the rivets from what I remember. you should be able to get a new lock and key set from the local parts store, but you might want to seek the help of someone when you go to install it. if you in PA email me and I can hook you up. iroc_07@yahoo.com
^jeeze, havent seen you in a very long time...
id do the basics and check the wiring and stuff too |
wiring
check the engine wiring?
check your wiper blades and wiring. It might be the left speaker also.
i got the engine to run but it won't stay on though. the engine chocks and dies. i checked all the wiring and i also checked the wiper blade wiring too "for the self- inspired mechanic" it wasn't the left speaker. i checked the intercooler it seems it isn't leaking.
