95 s14 lighting issue
Hi Everyone i have a 95 s14 and i just install some HID's. My problem is after i install the hid's the lights will only turn on it i have it on the bright light switch anyone no what can be causeing this?
you are using the wrong +12v wire to trigger the relay. be sure you are using the +12v wire from the low beam harness.
