-   Exterior/Interior/Lighting (https://www.s-chassis.com/forums/exterior-interior-lighting-92/)
-   -   S14 Kuoki SideSkirts on Zenki How? (https://www.s-chassis.com/forums/exterior-interior-lighting-92/s14-kuoki-sideskirts-zenki-how-41061/)
viral5523 Sep 2, 2007 08:27 PM
Ok, I need some help with this guys...
I just bought some S14 Kuoki OEM sideskirts and I want to mount them to my Zenki.
My question is How? The Zenki doesnt have any of the bolt holes used to mount them. I can deal with not having clips but I can't mount it at all without bolting it on the car. Anyone ever do this and if so how?
I don't want to use some crazy glue and mess it up.
Any help on this would greatly be appreciated....
silviaks2nr Sep 2, 2007 09:51 PM
since my kouki did not come with sideskirts i had to drill holes in the body and kind of wing it using washers and multi purpose screws. i used about 3 screws on the bottom on each side and of course the two on either end of the skirt. you could put some 3m double sided adhesive between the body and skirt if you wanted also.
viral5523 Sep 3, 2007 11:38 AM
Allright, I was thinking of using screws and I'd figured that I would have to drill holes but then how would I be able to thread the holes to use actuall bolts to hold up the skirts? I wouldn't mind using double sided tape but I assume it would mess up the paint on the car if I were to decide to remove them later.
slos14 Sep 4, 2007 08:34 PM
i used 3/4 in self tapers an they fit better than oem . just take your time if you do it right then ther is no need for to sided tape
