switch/button connector pictures
I would like to see if any one would PLEASE take pictures for me...
I need to know what connectors go to what switch/button on the dash panel, for the dimmer switch and all other switches there. I would also like pictures of how the tail lights/side lights connectors look like and also any other wire connector that I have not listed here please, any thing that is in or under the dash, I need to know the connector and what they are for. I would do this myself, but I do not have a 240sx nor access to a 240sx. I need the pictures to be from a 89-90 240sx COUPE, please Thank You in advance!!! |
count the prongs... you cant mix them up.... sorry im 1000000000 miles from my 240
(Post 387548)
I got discharged from the navy 5 months in for "depression", though it was only home sickness, but whatever. I do miss submarine school, I really was hoping to become a LT or better, but thats gone now, with that RE-4 re-enlisted code! I've tried counting them, but I'm really not sure about some of the plugs, I have to keep a few thats required for the motor to start and run. I've pretty much got all necessary relays relocated on the main engine bay harness with the fusible link box. This is becoming a larger project than what I thought it would be. I told the owner $330. for the labor + the wiring harness' ($100) and miscellaneous items (solder, electrical tape, etc) You can check my other post for more information about the project and maybe you might be able to help me on that problem also! https://www.s-chassis.com/forums/engine-swaps-13/wiring-harness-advice-needed-89-90-car-harnesss-46017/ |
oh dude your talking about the fuse box....... most of them only go to one spot.. the spades on the connectors are setup so that you cant mix them up. I have never re-did a fuse box on a s-13.
someone should be able to help ya out soon. also im doing fine in the military.. about to test for Staff Sergent... im also thinking about becoming an officer soon after i get my BA. Im in Iraq again at the moment making money. |
Woot Woot!!!! I made TSgt this cycle! Sew on in September!
