Windshield Wipers won't work
I was just wondering if anybody else had the problem of the windshield wipers won't work i don't think it is the motor because there is no voltage getting to the motor. Any ideas???
Thanks |
Did you check the relay/fuse? If you did, check the switch.
The wiper setup is not complex at all! :) Even on BMWs, it's pretty much a parallel circuit with an open/close switch. |
Check the fuse like he said...and check the accesory relay 1...behind the dash fuseblock...something else works off that relay too I can't remember, but that relay was bad and caused the wipers and something else not to work...if you have no voltage to the motor you need to backtrack. Start at fuse and work forward.
