300zx Fuel filter?
Can anyone show me a site to get the 300zx fuel filter. i looked around ebay and didin't see any. Any help is appreciated
-Joe |
never mind, found 1. http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
Will that fit my ka24de? What is the difference between the stock ka filter and the zx filter? |
wut i heard was burns fuel faster...i mayb wrong.
It's just bigger, It fits right in the stock holder with a little push! I put them in both my 240's just for ****s and giggles, it dosn't really make any diff in proformance. Just to to your local parts stop and ask for a 90 300zx tt feul filter. $12 and your on your way.
wut i heard was burns fuel faster...i mayb wrong yep your wrong :D |
yup see.....^-^ <^>
i'm using one for a 95 300zx TT.. don't know if that matters... it does give a little more performace but not really noticeable.. gives better throttle response with intake... I noticed that at least.
yeah, just out of curosity, does anyone else's car take a while to accelerate. Like if u punch it, does it take a while to get up to speed. Mine seems like it lags. I got alot of high end power but no low. What can i do to change that? I got an intake and a n1 exhaust
Originally posted by lrb_2000 i'm using one for a 95 300zx TT.. don't know if that matters... it does give a little more performace but not really noticeable.. gives better throttle response with intake... I noticed that at least. |
the 300zx fuel filter is slightly bigger than the 240sx filter, but as jbask said with a little push it will fit. No modifications needed nor do you need a new bracket.
in short.....IT WILL FIT |
Z32 fuel filter is direct fit on our cars.
the fuel filter holder will open wide enough to accomodate the larger fuel filter. provides more filter material and better flow of the fuel. |
aight thanks for the info, im going to do a tune up on my car today. Going to the auto store in a little bit. What do you guys recomend doing while ur doing a tune up. I was planning on changing the oil, trans fluid, gasket, and filter, spark plugs, fix my valve cover leak, paint my valve cover. Anything else?
cap and rotor? check all your fluids. check your tire pressure. I just woke up and can't think straight right now.
jsut got back from napa. Ordered finnaly a v/c gasket set which i have been needing for a very long time, injector cleaner, plugs, getting free oil and filters, free trans oil and filters, high temp rtv, and blue engine paint. GOnna paint my v/c soon :). Any other recommendations?
Originally posted by Atown 240 jsut got back from napa. Ordered finnaly a v/c gasket set which i have been needing for a very long time, injector cleaner, plugs, getting free oil and filters, free trans oil and filters, high temp rtv, and blue engine paint. GOnna paint my v/c soon :). Any other recommendations? I guess my tip is use the high temp primer even if they say you won't need it. |
