the antenna
the antenna
how do u get the antenna to come off the car. i am trying to fix my extendy antenna and i cant even unscrew the base to get it off. i tried using a screwdriver to loosen it up a bit and it wont budge. can anyone recomend a tool to use for this job? thanks in advance.
there is no where on the top to put a wrench. and the two recesses is where i put a screw driver into and tried to twist it with and that didnt work. i loosened up the panels in the back, but it looks like im going to have to take them out to get good room to play around with. thanks for the advise.
use a needle nose pliers. grab a hold of the top part of the antenna (top part should have small holes on them, not sure what it's for) then twist it off. mine was making an annoying sound so i took mine off. put a plug on the hole and installed an amplified antenna. makes it look clean and easy to install.
I used a small screw driver then the crome part on top of the antenna, right before the actual anntenna close to the center. Its a round soft chrome top part. It had 2 dents on each side. You put ur screwdrive there and hammer it softly but firmly in a counterclockwise turns and it should unscrew. Its hard but if gona throw it away, hit it like u mean it
