antenna/look questions
Old May 27, 2005 | 05:58 PM
robmiller's Avatar
Question antenna/look questions
I pick up my '98 S14 (SE) tomorrow. I'm very happy but I'm also very picky. The only thing I dislike is the rod antenna. I understand that the LE had a power/mast antenna, so I'm considering moving to that. However, I'm also curious on what fellow members do to achieve that "clean look."
Thank you in advance!
Old May 27, 2005 | 06:22 PM
Slidin240's Avatar
From what i understand you wanna eliminate the antenna and make it smooth. juss so you kno your gonna lose your "radio" (am/fm) if you eliminate the antenna.
What you do is take the whole antenna assaembly out and get some body filler and fill the hole where the antenna is. then sand, primer, sand again, paint. and viola its smooth.
If you never really worked with painting/body filler dont try this cus it might not come out smooth or match the rest of the car.
you can also just do the power antenna swap to it if your not up to the task.. lemme kno what you choose and how it comes out.
Old May 27, 2005 | 06:36 PM
robmiller's Avatar
cool! I haven't pulled the carpet in the trunk.. do you know if the mounting holes are there for the mast motor?
Old May 27, 2005 | 07:15 PM
Slidin240's Avatar
do you have the power antenna or the "stiff" one? either way its mounted in the trunk on the driver side. theres probably gonna be sum panels or carpet in the way but its easily accessable. lemme kno if you need any help.
AIM: Acesn8s240sx
Old May 27, 2005 | 07:36 PM
i have a little s2k one from ebay Name:  f5514920.jpg
its a little hard to make out sorry but yea
Old May 27, 2005 | 07:43 PM
Slidin240's Avatar
ive seen alot of 7th gen Celicas with that
Old Jun 1, 2005 | 08:19 PM
ramnailz's Avatar
I just took out my power antenna yesterday, and it wasn't hard at all. I got body filler from kragens and filled in that hole and sanded it down. It's really smooth, and it was my first time. You could always get an indoor small antenna and put it in on the rear panel dash were your speakers are at. Just to let you know, the motor was attached to a strip of metal with holes in it attached to the inner metal work.
Old Jun 2, 2005 | 07:01 AM
Slidin240's Avatar
post sum pics of it
Old Jun 2, 2005 | 11:16 AM
ramnailz's Avatar
Sure, they should be up later on tonight, got work. What pics do you want? Antenna hole patched? or the Power Antenna?
Old Jun 2, 2005 | 01:54 PM
Slidin240's Avatar
id like to see it all. i wanna see the good job u did
Old Jun 2, 2005 | 02:09 PM
ramnailz's Avatar
You guys just want to bash on me! J/K! Yeah, bondo is a weird compound, dries to quick I think. I used to make sculptures and things out of clay when I used to be into the "Arts" So it wasn't any different. If anyone wants I could set up a thread on a proper way to use it. I practiced on sheet metal, then I did my car, I liked it. N-E-ways, I don't know how to upload pics on this forum/thread, I'll try later.
Old Jun 2, 2005 | 03:00 PM
Slidin240's Avatar
host on on http://www.imageshack.ws/
then copy the direct link to image and paste it in between these guys, [*img], [/*img] (without the * tho, i juss added em so u can the commands)
yeh bro you should start a thread on it, thats some useful info man. (try to have pics of the process if you could, like on shet metal or w/e so people can get a visual)
Old Jun 2, 2005 | 05:43 PM
ramnailz's Avatar
I'll work on it right now. I'll show you guys the pics and the motor antenna. I got quite a few. I do a thread on it later.
Old Jun 2, 2005 | 05:47 PM
Slidin240's Avatar
more pics the better. i like 2 see every anlge of things
Old Jun 2, 2005 | 07:01 PM
ramnailz's Avatar
Alright, I don't know if this will work, but here it is. It's muggy outside so my camera didn't do a good job, I used my cell phone camera. Since it's been drizzling out, I need to patch up the side of the patch, there's a little rusty spots, bad! I'm not going to do a thread on patch work, the can of bondo is self explanatory. I say experiment, it's the best experience! Oh yeah my antenna motor is broken, that's why I took it out, I also didn't like it.
