-   General (https://www.s-chassis.com/forums/general-3/)
-   -   Automatic seat belt system failure (https://www.s-chassis.com/forums/general-3/automatic-seat-belt-system-failure-11396/)
Picur Apr 2, 2004 09:45 AM
Hi People!
Got a little problem with the Belt system mentioned in the subject.
The problem is, that the right shoulder belt is functioning , but the left one won't move. (It's frozen in the driving position)
Don't know if it's a power problem or something else.
The warning lamp is workin' and also the doorswitches do.
Somebody got an idea?
Thnx
Project Cheap13 Apr 2, 2004 09:53 AM
Try some grease in the tracks. If all else fails. Pull it all the way back & unplug it.
The guide could have broken, ect.. The easiest way to find out is to just take off the pillar pannels & look at it. Most of the time the damage is obvious.
Picur Apr 2, 2004 10:08 AM
Ok, i will have a look, but i'm sure something with the electrics must be wrong, because i don't hear any motor noise (should be there if only the guide is broken).
Could it maybe be the Fusebox? Because i had to work on it and then could unfortunatly kick out some cables? (The question is, where to find the control unit of this system)
Bryan Apr 2, 2004 03:51 PM
same question was asked like a week or two ago, its still on this first page
Here
nissandrift Apr 3, 2004 11:01 PM
I beleive the dealer will fix it for life on all 240's
ryan15 Apr 3, 2004 11:57 PM
Yea same thing happend to me. I need to go to the dealer and find out about getting it fixed for free.
Ryan
Picur Apr 5, 2004 04:03 AM
.. but here in hungary the nissan dealers are noobs..
most of them had never seen a 240sx..
homer240sx Apr 5, 2004 12:00 PM
try using a battery and hot wiring the motor if that works follow the wriing back to the fuse box or it could be that lil box under the center console.
