-   General (https://www.s-chassis.com/forums/general-3/)
-   -   Bushings (s14) (https://www.s-chassis.com/forums/general-3/bushings-s14-26569/)
birgir185 Sep 19, 2005 11:44 AM
Bushings (s14)
I was just looking under my and seeing that most of my busgings are worn out so i have been serching all day find out what options i have in bushings and i have come up with this list. did i forget something? is there maybe a more complete kit than the energy suspension kit
Energy suspension hyperflex bushing kit
• Front Control Arm Bushings
• Front Sway Bar Bushings
• Rear Sway Bar Bushings
• Front Strut Rod Bushings
• Tie Rod End Dust Boots
Energy Suspension
• Front Tension Rod Bushing Set
• Rear Sway Bar End Link Stabilizer Bushing
Whiteline
• Rear Upper Control Arm Bushings
• Rear Lower Control Arm Bushings
• Rear Camber Correction Bushings
• Rear Nissan Sub-Frame Align and Lock Kit
• Front Lower Control Arm Bushings
• Sway Bar D bar Bushings
• Front Sway bar End link donuts
Cusco
• Motor mounts
Tanabe
Transmission Bushing Set Drift Spec
Sustec Rear Sub-Frame Collars
Prothane
Front strut rod bushing kit
Tie rod boot kit
Total kit coming soon
Peak Performance
• Transmission Bushing Street
• Transmission Bushing Pro
Kazama
• Solid Engine Mounts
Nismo
• 3pc SR20DET engine mounts
• Rack pinion bushings
Phase 2
• Aluminum double subframe bushing kit
l2aine Sep 19, 2005 07:09 PM
There's a lot you missed if you're going for a complete list... URAS tranny mount, RS-R has a kit now too... etc.
Also the Nismo set isn't really a set- people just sell it that way. The Nismo motor mounts work for both KA and SR; same for the Nismo tranny mount.
