Intake Vaccume Line
Ok... Now does anyone happen to know why my transmission goes forward in all the gears.. I have an automatic.. I dont even need a key in the ignition to move the shifter.. Is my transmission messed up or do i have something hooked up wrong ?
BTW if you can move the shifter with the key out, then you also have a broken safety lock, but that's the least of your problems.
Is there such a thing on 240's?
Even if there was, a "TCU" on other cars is usually electronic. No electronic equipment on a 240SX would make reverse gear go forward, since the gear is part of a mechanical assembly.
Looks like you need an overhaul or a replacement.
aznchico69
05-10-2005 02:17 PM
PissonH
11-25-2004 07:38 AM
