Cam Chain Adjustment...
The cam chain guide, how much adjustment is there?
there is no adjustment in the timing chain guides... if they are making noise remove them per the fsm from nissan... or replace them with the units from 1998 dohc motors...
pull the guides, check if the oil=powered tensioner is moving freely. That's about all you can do.
Originally posted by l2aine pull the guides, check if the oil=powered tensioner is moving freely. That's about all you can do. |
