check engine light
how do i turn off my check engine light? the motor runs fine but the dumb light is on:angry:
you might want to investigate what caused it to turn on in the first place. check for codes. if you search the forum, you'll find out exactly what you need to do.
or, just pop out the cluster and remove the bulb. :thumb: |
Originally Posted by k_wakasugi
(Post 347294)
Originally Posted by alindeman1989
(Post 347282)
You should be able to pull the code yourself as well by pulling out the ECU and doing the whole turn the little knob and count how many times the light blinks, and then check out an FSM to see what the code is...
Originally Posted by tripperfx3
(Post 347364)
Just go to Autozone and get the code pulled. Its a free service.
dose doin this code finder thing work on the antilock brake light cause mine is on and i dont no what is causeing it
(Post 347364)
Just go to Autozone and get the code pulled. Its a free service. They'll tell you whats wrong and how to fix it. Also bring the code back here and we'll tell you what it is.
Originally Posted by Bryan
(Post 347367)
(Post 347393)
wow, i did not know that. pretty convenient.
very convenient if you have a obd II compliant and perhaps can vehicle.
Originally Posted by crazydrifter
(Post 347399)
this is only for the engine. |
(Post 347447)
on obd II and perhaps can compliant vehicles but not obd I
he has a '96 yes. very convenient if you have a obd II compliant and perhaps can vehicle. no. this is only for the engine. This is from OBD-II's website: Does My Car Have OBD-II? All cars and light trucks built and sold in the United States after January 1, 1996 were required to be OBD II equipped. In general, this means all 1996 model year cars and light trucks are compliant, even if built in late 1995. Two factors will show if your vehicle is definitely OBD II equipped: 1) There will be an OBD II connector as shown below, and 2) There will be a note on a sticker or nameplate under the hood: "OBD II compliant". |
