chris' 240sx project
3 Attachment(s)
ok so this is gonna be a build thread more or less so ill post pics of the build and info that i have and what i plan to do
so what i have done so far 1 got a ported and polished head from abicus racing 2 picked up another engine from a buddy 3 got a digital s13 cluster from the junk yard (as well as the sub harness and the projector) 4 painted some parts as well as cleaned some other stuff 5 picked up a grant steering wheel problems.... running into problems with the cluster, the high beam light not comming on the little blue light on the dash, as well as the tach moving up and down with the flashers and the dash lights not comming on but the tail lights light up .....now its a sohc car with a sohc tach into the cluster but i picked up the sub harness and it fit right in so im not sure if i messed up somewhere any1 got any input on the cluster? and last but not least going from a sohc engine to a dohc the wires above the ecu (for the guages and what not) will the sohc fit the dohc wireharness or will i need a dohc pigtail thanks for reading ill post more pictures and keep you guys updated as i go |
| All times are GMT -7. The time now is 02:59 AM. |
