-   General (https://www.s-chassis.com/forums/general-3/)
-   -   Clutch Adjustment (https://www.s-chassis.com/forums/general-3/clutch-adjustment-7470/)
ryan15 Nov 16, 2003 05:41 PM
Clutch Adjustment
could some one help me out with adjusting my clutch, i have no idea where to even start.
Thanks
Ryan
-HyJynX- Nov 16, 2003 09:09 PM
You mean clutch pedal adjustment?
BeteNoir Nov 16, 2003 09:14 PM
Yes clarify please.
ryan15 Nov 16, 2003 09:20 PM
im not really sure but i think that might be it.
OK here`s whats up, you have to let out the clutch pedal almost all the way untill it engages.I hope that helps
Ryan
-HyJynX- Nov 16, 2003 09:24 PM
0k there is to much play in the pedal. Check this site out...its really helpful http://**********/faq/index.html then go to clutch pedfal adjustment, that should solve ur problem
BeteNoir Nov 16, 2003 09:33 PM
Ryan
And this is a bad thing??
Neway.... follow the clutch pedal arm up to the push rod that slides into the master cyl. There is an adusting nut behind the bracket. Back it off a few turns and rotate the push rod clockwise (from driver's seat) to adjust. Find the right setting and lock the adjusting nut.
You may also need to bleed the system if the pedal feels too soft.
Actually, just do what he /\ said.
ryan15 Nov 17, 2003 09:25 PM
ight it was actually counter clockwise to fix the problem it was really easy thanx for helping me out
Ryan
-HyJynX- Nov 17, 2003 09:26 PM
Awesum:thumb: Glad we can help ya out
BeteNoir Nov 17, 2003 09:39 PM
Hey its not my fault that my mom didn't teach me my clockwise from counterclockwise. lol
Glad to be of help.
