cold air intake air sensor?
umm ok guys i made a thread similar to this but i need more help now the o2 sensor running to the stock air box what do i do with the hose? keep it open or plug it up? any type of help would be greatful.
-well if your wooly mammoth converter isn't plugged in then your dragon's blood detector won't work properly with your flux capacitor...
-your o2 sensor is in your header. The hose comes from your IACV. This can be removed.
is it the aiv or air temp sensor you're talking about?
as mentioned the o2 sensor is on the header/manifold.
fixed my typo aiv not iacv
^^^ What? The IACV and the EGR aren't connected. He would only have to plug the two vacuum lines and plug the header where the line came off.
-#1 is what he is talking about and it has nothing to do with the EGR.
-P.S. I don't know if it makes a difference, but we're talkin' twin cams here.
SURFMAN-
09-21-2003 06:31 PM
