-   General (https://www.s-chassis.com/forums/general-3/)
-   -   Dead from Heat feels like you are in hell but you are only in an S13 (https://www.s-chassis.com/forums/general-3/dead-heat-feels-like-you-hell-but-you-only-s13-12700/)
mango02 May 21, 2004 06:33 PM
Not sure about which FORUM? Drivers side window does not operate, I can hear the relay clicking. Tried to remove door panel. Screws, window switch are out panel is loose but I CANNOT REMOVE THE PANEL BECAUSE IT'S HUNG ON THE DOOR HANDLE AND LOCK. How do you remove this freaking panel without busting up the door? I have a FSM but no help?
Project Cheap13 May 21, 2004 08:34 PM
Did you take off the little cover? If not it just prys off with a flatblade screwdriver.There are 2 "clips" that hold it on towards the back. one on top & one on bottom. Pop it off & you are home free.
mango02 May 22, 2004 08:01 PM
The dude that had the car before me EPOXYED the Escutcheon plate, door panel toghter. Had use a Hacksaw Blade from long distance and cut the EPOXY away. Got the motor off Regulator cleaning the amature and brushes trying to get it to work. Used a meter and it has power all the way to the motor. Thanks for the help.
